18 years agoaltddio_in, altddio_out msb, lsb confusion
Hi, if I connect an altddio_out output to an altddio_in input, do I have to swap over the final output single data rate bits from the receive function? i.e. In the altddio megafunction u...
18 years agoThanks,
I've done a sim and it confirms what you said. It strikes me as a bit strange that it works that way but as long as I understand it then I should be able to make it work. Regards, Dave.
