18 years agoaltddio_in, altddio_out msb, lsb confusion
Hi, if I connect an altddio_out output to an altddio_in input, do I have to swap over the final output single data rate bits from the receive function? i.e. In the altddio megafunction u...
18 years agoI remember being equally confused when I first use these megafunctions. Assuming that nothing has changed since I last used these megafunctions in 6.1:
datain_h is the data that will be driven to pin on rising clock edge datain_l is the data that will be driven to pin on falling clock edge dataout_h is the data on the pin while clock was low (captured rising clock edge) dataout_l is the data on the pin while clock was high (captured falling clock edge) Connect an altddio_in and an alt_ddio_out together and run a quick sim on it to see the results. The short answer is whatever you clock out on datain_h and datain_l will show up on dataout_l and dataout_h respectively on the following clock cycle. Jake
