15 years agoalt_write_flash_command_16bit_device_16bit_mode fails
I have a prototype board based on Cyclone III 3C40 FPGA. There is 16M external flash. On the top level, alt_flash_dev* dFlashFD =alt_flash_open_dev(FLASH_NAME); returns 0. On low_level, it fails alt_write_flash_command_16bit_device_16bit_mode which shall return "QRY", but some other codes. The external flash is 16Bits Intel 128P30. Anyone has any hints that what causes flash not functioning? Thank you, DavidNo RepliesBe the first to reply
