15 years agoalt_read_flash()
Hello, What is the meaning of 5000 in alt_read_flash(fd, 0, dest, 5000)? I cannot understand the arguments inside alt_read_flash. I read a few articles and notes but still cannot get its meanin...
15 years agoint alt_read_flash( alt_flash_fd* fd,
int offset, void* dest_addr, int length ); In the "Using Flash Devices" section of the Nios II SW Developers Handbook. "A call to alt_read_flash() reads from the flash device with the handle fd, offset bytes from the beginning of the flash device. The function writes the data to location pointed to by dest_addr, and the amount of data read is length. For most flash devices, you can access the contents as standard memory, making it unnecessary to use alt_read_flash()."
