12 years agoALT_LVDS timing fails for core clock
Hi, I'm using Quartus 13.1 with a Stratix IV GX dev kit. Trying to implement a simple test design for a 6 bit deserialiser using ALT_LVDS Rx. But I'm getting timing errors in a weird pla...
12 years ago --- Quote Start --- I can see the register clocked by rx_outclk so the reported path does not exist. Clearly wrong reporting unless fitter removes it which I doubt. hold multicycle must always be 1 less than setup multicycle (for all source sync cases) as this says the launch/latch edges are those aligned with zero relationship so 5 is ok. --- Quote End --- I'm sorry. I don't understand. The reported path is the one between the SERDES blocks and the register. The dataout from the serdes is at fast clock. And the register is clocked at slow clock. It is still within the LVDS megafunction. This should always work..
