15 years ago"alias" problem in fixed_pkg
sir, i am using fixed_pkg_c.vhd.during synthesis it gives error on alias statement.if i remove this "alias " only, it gives error
". ERROR:HDLParsers:164 - Line 1024. parse error, unexpected IDENTIFIER" the program copy where it gives the error is "function to_slv ( arg : UNRESOLVED_ufixed) -- fixed point vector return STD_LOGIC_VECTOR; to_StdLogicVector is to_slv [UNRESOLVED_ufixed return STD_LOGIC_VECTOR]; to_Std_Logic_Vector is to_slv [UNRESOLVED_ufixed return STD_LOGIC_VECTOR]; -- plz sir help me.............:cry:12 Replies
Did you notice the vendor specific adaptions of the IEEE fixed-Pkg? http://www.eda.org/fphdl
--- Quote Start --- @triky sir , after correcting as per your advice (i.e 0.46 instead of .46),it gives error that :line 1031: alias of a function is not supported. --- Quote End --- Id have thought that error was self explanitory. - Altera_Forum
As said, the code compiles in Quartus, so it's apparently a Xilinx XST related problem. Ask the Xilinx guys.
at the line : function to_slv ( arg : UNRESOLVED_ufixed) -- fixed point vector return STD_LOGIC_VECTOR; error -------> alias to_StdLogicVector is to_slv [UNRESOLVED_ufixed return STD_LOGIC_VECTOR]; alias to_Std_Logic_Vector is to_slv [UNRESOLVED_ufixed return STD_LOGIC_VECTOR]; - Altera_Forum
@ triky sir,
my code is : library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.all; use WORK.math_utility_pkg.all; use work.fixed_pkg.all; entity nitu is Port ( a : in ufixed (2 downto 0); c :out ufixed (2 downto -3)); end nitu; architecture Behavioral of nitu is signal n1 : ufixed (0 downto -3); begin n1 <= to_ufixed(.46,n1);<---------- ERROR LINE.:oops: c <= a *n1; end Behavioral; ERROR :Line 42. parse error, unexpected POINT. - Altera_Forum
You still havent said what the error is.
Looking at your code you have this line: n1 <= to_ufixed(.46,n1); change it to n1 <= to_ufixed(0.46,n1); - Altera_Forum
sorry sir,now i don't remove alias. now how will i rectify the error?
--- Quote Start --- then sir how will i rectify error occured due to "alais" statement? --- Quote End --- You never said what the error with the alias statement was - just that you deleted the word "alias". Secondly - your project is a Xilinx project. We cannot help you with that - this is an altera forum. - Altera_Forum
