16 years agoAHDL Syntax Manual
Does anyone have a link or a PDF copy of the AHDL syntax manual? I have a design to translate which was originally done in AHDL. Thanks, Darrell Ray
16 years agoI found just searching for "AHDL" in the quartus help can be quite helpful.
I have found having a good knowledge of another HDL helps, having done reading/translating of AHDL. Its quite straightforward and only really a netlist. You do have to get used to the idiosyncracies, like any .d or .en input on a register is set to GND by deafult when not set in a given state, when in VHDL it would hold value. AHDL wants you to be quite explicit.
