Agilex F-Tile bus reversal / twist
In the shared zip files, IP files are missing. Please the QAR file.
Also, as you have mentioned you don't see this issue in Q23.3. Please confirm.
Thank you,
Kshitij Goel
No, that's not what I said. The problem exists in Q23.3 for the AGI027 target device. I do *not* see the bus twist issue when I target the AGF014 device. Seems to be an "I-Series" versus "F-Series" target issue, likely because the F-Series device was equipped with E-Tiles.
I have provided you with more than enough information and supporting documentation for you to replicate this problem on your own. It's super easy ... barely an inconvenience. I'm not going to do your job for you, and I'm certainly not going to do so without monetary compensation. Normally I'd offer you a consulting rate ... but I don't think I'll do that this time.
Have a nice day.
