18 years ago
Add Custom SRAM to NIOS
Hi to all,
does anybody know how to add a custom sram to my Nios II system?
I mean that I instantiate a Tristate Avalon Slave in SOPC builder that is compliant with my sram but subsequently I cannot select this memory inside "Nios IDE" on page "System Library" where I usually select "Program memory (.text)", ".rodata", "stack", "heap", etc...
Thank you
    Thanks to all.
    User Viper21 from NiosForum figured out how to fix this problem.
    After creating a component, located and open up the .tcl file.
    Find the line "isMemoryDevice” and change the value from "false" to "true".
    Many thanks to him.
    However, I am astonished that there is not a check about it in SOPC builder...
    --- Quote Start ---
    Can you connect your component to the Nios II? Version 7.2 yhad an issue witht his
    --- Quote End ---
    Thank for your reply.
    Yes, I can see all the output pins in the block.
