13 years agoADC0804 interfaced with CPLD
Hello All, I am trying to interface an ADC0804 with a CPLD. The ADC0804 has potentiometerat the input. I have successfully tested the ADC using LEDs at the output, itworked fine. I am now movin...
13 years ago --- Quote Start --- I am a bit confused here, I have already managed to reduced the 25 MHz to 625 KHz using a counter. Is this what you meant or do you mean I have to reduce the 625 KHz further. --- Quote End --- You stated in the message above "I feel better connected the CPLD clock frequency to the ADC", so I just wanted to make sure that you knew you needed to use a slower clock. You obviously do, so you're all set! Cheers, Dave
