13 years agoADC0804 interfaced with CPLD
Hello All, I am trying to interface an ADC0804 with a CPLD. The ADC0804 has potentiometerat the input. I have successfully tested the ADC using LEDs at the output, itworked fine. I am now movin...
13 years ago --- Quote Start --- Thanks again, I am sorry the link for the hardware is below. http://www.matrixmultimedia.com/resources/files/datasheets/eb020-30-3.pdf --- Quote End --- The CPLD is powered from 5V, so you can connect this to the ADC ok. --- Quote Start --- I feel better connected the CPLD clock frequency to the ADC. I will have a go at this tomorrow and get some output traces. Before testing it actually on the hardware. --- Quote End --- You need to create a slower speed clock in the CPLD and then connect that to the ADC. You would create the slower speed clock using a counter. The counter can be used to count the half-period of the clock you want, and then you toggle the clock output every time the counter completes (asserts carry-out). This gives you a nice square wave for the output clock. Cheers, Dave
