16 years agoActive Host File System from NIOS II ECLIPSE
Hi, I need help with reading/writing files, from the NIOS II target with a PC file. My IDE is ECLIPSE, so: I don't have the project->properties->Associated system Library->System Library ...
15 years ago --- Quote Start --- Hi, I need help with reading/writing files, from the NIOS II target with a PC file. My IDE is ECLIPSE, so: I don't have the project->properties->Associated system Library->System Library oroerties->Software Components->add this SW Component. So what's its equivalent. Thanks:confused: Yossi --- Quote End --- I meet the same difficult,have you solved you problem?
