13 years agoAcross clock domains problem
There are two main clocks in my project, one is 250MHz, antoher is 100Mhz. A counter counting according 250MHz clock. I want to register the counter's value at some conditions, and send this value in...
13 years agoyou would want at least a double register to get it "safely" across the domain. But how often are you going to read it? if its rather infrequently, and its set infrequently, then this method should be safe enough.
