17 years agoAccessing CRC_ERROR circuitry in user logic
Hello, We plan to use the CRC_ERROR function of the Stratix II device, but I'm having a hard time to understand from the handbook and AN357 how I can access the block from user logic. What I'd ...
13 years ago --- Quote Start --- You're going to have to use the CRC_ERROR pin, but once you bring it back into the fabric via the bidir, you can do whatever you want with it -- including routing it to another output pin. --- Quote End --- Which is all a bit pointless really because if the FPGA does incur an SEU then that may well involve the pin routing CRAM - which in turn means the rerouted CRC_ERROR pin may well disappear on a CRC error!
