17 years agoAccessing CRC_ERROR circuitry in user logic
Hello, We plan to use the CRC_ERROR function of the Stratix II device, but I'm having a hard time to understand from the handbook and AN357 how I can access the block from user logic. What I'd ...
17 years agoThere isn't a megawizard for the CRC configuration verification function. To access the CRC_ERROR function internally, you'll need to manually instantiate the <device>_crcblock primitive (cycloneiii_crcblock, for example). The verilog instance is in the app note, the VHDL component (for cyclone III) looks like this:
component cycloneiii_crcblock generic ( lpm_type : string := "cycloneiii_crcblock" ); port( clk : in std_logic := '0'; crcerror : out std_logic; ldsrc : in std_logic := '0'; regout : out std_logic; shiftnld : in std_logic := '0' ); end component; This one was found in the cycloneiii_components.vhd file in the ...\quartus\libraries\vhdl\wysiwyg directory in your installation directories. Once you instantiate this in your code, connect the crc_error port to a bidirectional pin. You can then use the input function of that pin to access the CRC_ERROR signal in your design. I don't think Quartus will let you access CRC_ERROR any other way, since there's a dedicated path from the error detection logic to the I/O cell, so it had to pass through a bidir pin before being available in the FPGA fabric. I hope that helps.
