13 years agoaccess to usb device in serial way
I want to connect FPGA to PC with usb device, but most applications access devices by serial (COM port). Is that possible let usb device appear as an additional COM port? Thanks!
13 years ago --- Quote Start --- I have DE2 board --- Quote End --- Ok, thanks. --- Quote Start --- Using network interface sounds great, I will try both of this. --- Quote End --- You said you are a beginner in FPGA, are you also a beginner in writing software? If you are familiar with software then I would recommend; 1) Creating a NIOS II system containing a server (there are "simple socket server" examples), and write sockets code to test it. 2) Write MATLAB sockets code. 3) Modify the design in (1) to provide access to whatever FPGA hardware you want to test. You can also go through the tutorial I linked to. If you do not require high bandwidth for your data transfer, then using JTAG may be adequate. Cheers, Dave
