10 years agoAbsolute maximum I/O/Analog pin input current
Hi, For the MAX10 family, what's the absolute maximum input current? Altera gives only the absolute maximum voltage (=4.12V). In my application I'm sampling with the MAX10 ADC an analog si...
10 years agoHi,
I assume you're looking for "DC output current per pin", which is +/-25mA. I guess you were looking for a "DC input current per pin" or so; I doubt you'll find that, as I think that the +/-25mA limit is the maximum the input protection diodes can sustain, i.e. you're in a region where the pin isn't acting as a normal input any more. Since the maximum input voltage is 5.88V below of what your application might apply, I'd suggest to use an input buffer, i.e. some simple OP-Amp. Depending on your application, a simple RIRO-OpAmp, using the same rail as your I/O bank, could already do the trick. Best regards, GooGooCluster
