15 years agoAbout the FPGA
I need to make my FPGA automatically to read the .hex fire (which is a test program) when I synthesis my CPU core (openMSP430) to the FPGA. Where should I put this hex fire ,in the FLASH or SDRAM, an...
15 years agoFPGAs require well regulated voltages. You shouldn't put any resistor between the regulator and the FPGA...
Yes, you need a SRAM in the FPGA. You need to take a look into the OpenMSP430code to see how to initialize the memories.
