15 years agoAbout the FPGA
I need to make my FPGA automatically to read the .hex fire (which is a test program) when I synthesis my CPU core (openMSP430) to the FPGA. Where should I put this hex fire ,in the FLASH or SDRAM, an...
15 years agoCan I use Control Panel to upload hex fire to SDRAM or FLASH? But even I have uoload the hex fire. I still need do some work to make the CPU can automatically read the hex fire, right? I am a newer of FPGA. I will use Powerplay analysize and voltage scope two methods to measure the power of CPU core. I have insert a resistor in the power supply of the CPU core. As my project is to "Investigate the effect on energy consumption of instruction set reductions in the OpenMSP430". So I need to measure the power accurately.
