15 years agoAbout the "Demo how to use TRDB-D5M with LTM on DE2-70"
Hi Friends,
I used to run the "Demo how to use TRDB-D5M with LTM on DE2-70", but i can't, i found one error before downloading the program in the EEProm of the FPGA DE2-70, in the debug phase, The error found is the following : "Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x01401070: ID value does not match: read 0x5C716C23; expected 0x59DA1B27 Timestamp value does not match: image on board is older than expected Read timestamp 8:43:18 2008/10/24; expected 14:38:41 2011/08/15 The software you are downloading may not run on the system which is currently configured into the device. Please download the correct SOF or recompile. Restarting target processor" I used the Quartus II 9.1 Web Edition You find also joined with this email the program that i trie to run, Please help me to run this program, I want to know the different step that i must do befor running this program, also i want to know what is the error done Think you1 Reply
As the error message suggests you should upload the .sof file that corresponds to the software you are trying to upload.
And each time you do a change to the SOPC builder project, you should recompile both the Quartus hardware project and the software, upload the .sof image, and then upload the software.
