14 years agoabout the CONF_DONE in the PS configuration
Dear all, I am trying to configure the Cyclone III device using the Passive Serial mode. In the very beginning, I draw the nCONFIG low, and subsequently the Cyclone III draw the nSTATUS low....the qu...
13 years ago --- Quote Start --- Probe setup as little endian 0xfe50_0020 f7f7f76a f3f3f3f7 fbfaf3fb f9f9f1fa Probe setup for big endian 0xfe50_0020 6af7f7f7 f7f3f3f3 fbf3fafb faf1f9f9 --- Quote End --- In both cases the bytes are; 6a f7 f7 f7 f7 f3 f3 f3 ... which matches your .rbf. This at least confirms your bytes in flash appear to be correct. How are you PS programming? Using an SPI controller? Check the bit-ordering with a scope. This document may give you some hints too ... http://www.ovro.caltech.edu/~dwh/carma_board/fpga_configuration.pdf Check the different control signal pulses match their expected timing. Cheers, Dave
