18 years agoabout starting reconfiguration~
hello,
my board has cyclone1, epcs,and ext_flash ,and so on. now, i want to start the reconfiguration, not using re_por or low_to_high conversion of reconfig pin, i see the "altremote_update Megafunction" datasheet, but it desen't supported the cyclone1, so is there anyway to start the reconfiguration? thanks.4 Replies
hi,
i don't want add extra electrocircuit (javascript:void(0)), so i want to know if the fpga can reset itself via doing some operation. - Altera_Forum
Cyclone I has to dedicated remote update hardware, the only way to trigger a reconfiguration is by the nconfig pin. This is also the most simple way. I don't yet understand, why you don't want to use this option.
hi,
sorry for my poor english. i want to start the reconfiguration of fpga, and don't want to use re_por and low_to_high transformation (javascript:showjdsw('showjd_1','j_1')) of nconfig pin to start the reconfiguration, if the fpga can start the process by itself? - Altera_Forum
--- Quote Start --- not using re_por or low_to_high conversion of reconfig pin --- Quote End --- Why? You didn't tell in your previous thread why the suggested solution doesn't work for you. May be, there is an issue, but I didn't see it yet.
