15 years agoAbout PLL_OUT as LVDS clock
I want to generate a 500MHz LVDS clock as the LVDS sampling clock for the ADC by a ALTPLL in EP2S15F484C4. I followed the example in ug_altpll.pdf downloaded from Altera. 1.Select a dedicated CL...
15 years agoThank your quick relpy.
PIN_AB10 is column I/O,but PIN_J5 is row one. I just selected EP2S15F484C3 to compile,the compilation report errors are still same as before. I have to select LVDS which is the only one interface I/O standard the ADC uses. Regards. --- Quote Start --- Refer to the maximum output toggle rate table in Stratix II handbook. It tells that 500 MHz LVDS should work for row I/O pins, but not for clock outputs. I wonder, if other differential I/O standards may be applicable for your design? --- Quote End ---
