15 years agoAbout maximum RAM data rate in Stratix II
I want to store the data acquired by a ADC for later processing.The data rate is 250MHz and data width is 32bits. I generated a 256*32bits 1-port RAM with 250MHz inclk and 100MHz outclk by megafuncti...
15 years agoIf you are using classic timing analyser then you don't need sdc. All you need is enter clock details, as well as tSU/tH/tCO for external interfacing.
If you have achieved 300MHz then that's it. If the ram block can't go that fast then the tool will not give you that fmax.
