A10 SoC: issue with .sopcinfo file while generating dts file
Are you trying to use the hard memory controller dedicated to the HPS or connecting the H2F bridge to a separate memory controller through the FPGA fabric? If it's the dedicated controller, you need to enable its use in the HPS parameters and connect the conduit interface that gets enabled to a special IP for this purpose (Arria 10 External Memory Interface for HPS).
If indeed you are going through the fabric, altera_emif is the correct IP to use. Does the system generate successfully from Platform Designer before you run sopc2dts?
#iwork4intel
i am trying to connect the memory controller ,"External Memory Interface intel Arria 10 FPGA IP" to the HPS h2f_axi_master bus.
Yes,the Generation was done successfully and even i could find the component declaration in the sopcinfo file as
" <module name="fpga_emif1" kind="altera_emif" version="18.0" path="fpga_emif1">"
