15 years agoA trouble With Code
Hi all, well am a new VHDL programmer, and I was trying to write a code for a generic multiplier using a 4 bit ripple adder, the results are correct, but my design should include two modes, test m...
15 years agoTo avoid double drive on "output" connect "temp1" to multiplier output at G0 line and assign temp2 instead of output in the line:
output(n+3 DOWNTO 0)<= input1(0) & output(n+2 DOWNTO 0); Then create a switch: if ... output <= temp1; else output <= temp2; end if;
