15 years agoA timing closure problem.
I have suffered a timing closure problem. I use the Arria II GX device and Quartus 10.1 without SP . In my design , I use the DSPBuilder ADV Block create a IP. In the IP , after the inputs pass throu...
15 years agoThe figure give the data arrival path with the worst slack. Based on your suggestion , I explored my design and found the fan in to the combinational block is not too much. But after using the command your suggested to analyze the failing path. I found that there are too much intermediate nodes for the failing path. These nodes need a lot of lcell to fit , and will make the path between source and destination go through several LAB , and not a LAB. Thanks , Rysc.
