15 years agoA question about power analyzer tool
I used power analyzer tool to estimate the power consumption of my design (a vcd file). I find the current flow into VCCINT is nearly 7mA, Since I inserted a resistor in the power supply rail of the ...
15 years agoThank you for your reply! Except the toggle rate, what else will cause this difference? If there are some references where I can have a look will be better. I have another question. If I changed my microcontroller, like reducing the number of registers, in the theory, Should there be some change in these current values? But I find these values nothing change. When I reduce some registers or reduce some instructions, or even reduce a hardware multiplier. I am not should if I did the wrong thing. Thank you for helping!
