VGolo1
6 years agoA problem with Cyclone/Arria 10GX Transciever
Hello everyone! I need help! I have two modules based on Arria 10GX (10AX066H4F34E3SG) and Cyclone 10GX (10CX220YF780I5G). The task is to make a 1G fiber Ethernet (1000Base-X) using GX functions of...
Deshi_Intel
6 years agoHI,
I see. Unfortunately our TSE IP reference design is based on what I shared with you using LVDS IO.
On the other hand, NativePHY IP itself is just a skeleton IP where we freely allow customer to build any custom protocol solution on top of it. There won't be any reference design on it as reference design is developed to target certain application protocol.
For your case, the more appropriate reference design for you will be Ethernet PHY IP that can run on 1G.
You can checkout below LL Ethernet 10G MAC IP where you can customize the setting to generate Ethernet MAC + PHY example design that support 1G application.
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_32b_10g_ethernet_mac.pdf
dlim
