VGolo1
6 years agoA problem with Cyclone/Arria 10GX Transciever
Hello everyone! I need help! I have two modules based on Arria 10GX (10AX066H4F34E3SG) and Cyclone 10GX (10CX220YF780I5G). The task is to make a 1G fiber Ethernet (1000Base-X) using GX functions of...
VGolo1
6 years agoThank you for your answer but this project is based on Marvell 88E1111 chip and I need a direct connection between FPGA and SFP. Moreover, the project uses LVDS I/O instead of GX functions. My PCB uses GX functions and pins. Should I use TSE or Native PHY and can you give me any applicable example?
