15 years agoA problem on I2C, which may cause by the pin to pin resistance on the emulation board
Dear Sir, I met one problem as the attachment. The voltage drop is supposed caused by the pin to pin impedance, I guess. Because pin to pin resistance is about ony 30K to 40K Ohms which is...
15 years agoFrom your draqing: Problably the pull up on the SDA/SCL line is too high. For most I2C busses the internal pull ups of fpga's are to high in value. A 4.7kOhm pull up on the lines is a good starting point. Or some device is loading the bus ...
