14 years agoA little help with C in NIOS II
I'm hoping someone can give me a bit of help with my C code! basically i have the audio in and out routed into NIOS. It works fine but i want an if statement around it so the audio out equals a...
14 years agoTHAT was a great reply. Thanks very much!
Eventually i will have a selection of hardware audio effect modules routed into nios. I want to be able to be able to connect them in series ( eg output of block 1 to input of block 2) depending on which order the switches are switched - slide switches. It should be reconfigurable so effect blocks can be rearranged in order - a basic effect chain really Anyway, this was the first step Cheers
