19 years ago5V Tolerant Devices
I created the attached so that I could quickly reference which Altera devices are 5V tolerant. All of these devices have a Vih > 5V. I've also added PDN information as I find that useful. Hop...
19 years ago --- Quote Start --- This is a good post. However I am not sure if I understand the table completely. Can you explain what the different numbers mean under the package, ex: for EP20K100 you have 2X and 2 under T144 column? Thanks. --- Quote End --- Those are speed grade designations. In the APEX 20K (nonE) family, the -X indicates PLLs are available. -1X is the -1 speed grade with PLLs. -2 is -2 speed grade with no PLLs. http://www.altera.com/products/devic...at.html#table1 (http://www.altera.com/products/devices/dev-format.html#table1)
