15 years ago5V to 3.3V bus and vice versa
MC68000 to CycloneII There is something wrong with quickswich devices. As I know MC68000 cant support 3.3V (some versions can but mine just cant). When i use quickswich any type i only get ...
15 years agoThese clamping devices need low ohmic pull-up to achieve sufficient speed at the high voltage side. This may be a problem with the drive strength of MC68000. But if the bus speed requirements aren't too high, it should work.
In addition, I don't understand, why you can't generate a direction signal from the MC68000 bus control signals? Any kind of bus extenders does it.
