15 years ago5V to 3.3V bus and vice versa
MC68000 to CycloneII There is something wrong with quickswich devices. As I know MC68000 cant support 3.3V (some versions can but mine just cant). When i use quickswich any type i only get ...
15 years agoAre the signals going from the Cyclone II to the MC68000 'fast'?
If they are 'slow', then can you consider putting pull-ups to 5V on the signals (bus pull-ups)? The Cyclone II device can then drive high (to Voh ~ 3.3V), and then tri-state the output driver, the pull-up can then take the signal over the last few volts to 5V. 5V I/O clamps can then be used on the Cyclone II I/O to protect it from the 5V signals (see the DE2 board GPIOs). Cheers, Dave
