15 years ago3.372 MHz and 7.5Mhz and 4Khz
I need to generate clock for 3.372 Mhz, 7.5 MHz and 4 Khz. is this possible using dividers in the dE0 or the DE0 nano board?
15 years agoall right, I will help you as far as you and I can.
first of all. if you know how to generate Altera's IP-Megacorefunction. if you do that. just read the document here http://www.altera.com/literature/ug/ug_altpll.pdf and generate IP-core Start QuartusII -> select [Tools]-> [MegaWizardPluginManager]menu -> create a new custom megafunction -> select ALTPLL in I/O tab in the IP-Megafunction you can choose input clock(50MHz in DE0 nano) and output clocks ( what you want create) this is rough description. if you have the board. just try it and check it out with an oscilloscope.
