15 years ago3.372 MHz and 7.5Mhz and 4Khz
I need to generate clock for 3.372 Mhz, 7.5 MHz and 4 Khz. is this possible using dividers in the dE0 or the DE0 nano board?
15 years agosince nobody answers you.
you can craete 4KHz from 64MHz divided by 16. also, you can create 7.5MHz from 50MHz. I have a question. do you really need to create "exact" 3.372 MHz from 50MHz? I tried creating 3.372 from 50MHz I could create 3.371993MHz instead of that. is that enough for you?
