15 years ago24bit counter by 400 MHz
Hi all, i am working with Cyclone III Starter Kit, the max frequency is 400 MHz. I would like to use this high frequency to achieve a 2.5ns resolution. with the megafunction i can easy make the ...
15 years agoIf you want 24 bit counter running at 400MHz that is one issue, but if you just want 2.5ns time resolution then a single register running at 400 MHz may be do the job without counting. You send a changing input and check at the output of the register or Xor the input and output of that register resulting in a 2.5ns pulse.
