16 years ago100KHz 16bit PWM generation -- PLL manipulation?
I would like to replace my TI Picccolo with an FPGA. The one major thing that the Piccolo has is the ability to generate a PWM signal with a resolution of 150 ps (yes, pico seconds), thus allo...
16 years agoYes, you surely have to handle coarse and fine timing separately. The interesting problem is to keep an absolute timing reference for the phase shifted clock. I can't give you detailed suggestions, because I didn't use dynamic phase shift for the said purpose. But I'm convinced that it can work. Good luck!
