16 years ago100KHz 16bit PWM generation -- PLL manipulation?
I would like to replace my TI Picccolo with an FPGA. The one major thing that the Piccolo has is the ability to generate a PWM signal with a resolution of 150 ps (yes, pico seconds), thus allo...
16 years agoYou should be able to fine-shift a pulse edge utilizing PLL dynamic phase shift capability, achieving the said resolution (1/8 of VCO period). As long as you don't need other high performance features, it should work also with Cyclone III.
Interesting points are intended update rate and number of parallel channels. I wonder however, if a fractional PWM modulator design can't achieve the same resolution with less effort?
