13 years ago.rwdata and .bss do not work with custom memory controller
Hi, I have designed a custom SRAM memory controller connected to a NIOS II processor that - as far as I can see - works. Running a test program from on-chip memory, reading/writing happens with...
13 years agoIt works! Thank you both for your replies :)
All along I have been assuming it is a problem with the read/write bursts. Turns out pantxoa was right and I accidentally disconnected the byte enable signals. Merci beaucoup pantxoa, you have saved me a lot of bother!!
