17 years ago.RBF file to download in serial configuration ?
i have a little question, i use a ep3c40q240c8 (cyclone iii) with epcs16 (serial configuration) and i have a microcontroller also. i would like to upgrade the fpga code inside the serial...
17 years agoHi Jean,
We need to program Active Serial mode bit stream into EPCS. I don't think we can make a .RBF file for Active Serial mode. So, you have to use .RPD data in Active Serial mode for EPCS programming. --- EOFZ
