AFies
6 years agoWriting the CFI flash of the Arria 10GX Dev Kit via JTAG.
2 Convert bts_config.sof to bts_config.flash intended for updating user hardware1 portion at 0x02D00000.
sof2flash --input=bts_config.sof --output=bts_config.flash --offset=0x02D00000 --pfl --option...
YuanLi_S_Intel
6 years agoHi,
Yes, the TCK frequency has to be lowered in order to work perfectly. Usually, we will recommend to lower to 6MHz.
Meanwhile for the sof2flash, may i know which user guide and example are you following?
Thank You.
Bruce
