Ernesto-Sola
4 years agoWrite to EPC in DE10-Nano
I have been now for a while trying to write to the onboard EPC in the DE10-Nano board, and I have not been able to. I have followed step by step the datasheet, changed the dip pin configura...
YuanLi_S_Intel
4 years agoFor this error message, can you check the following?
"Error (209025): Can't recognize silicon ID for device 2. A device's silicon ID is different from its JTAG ID. Verify that all cables are securely connected, select a different device, or check the power on the target system. Make sure the device pins are connected and configured correctly."
