Write to EPC in DE10-Nano
What about the device part number used? is it the same as DE-NANO using?
- Ernesto-Sola4 years ago
I think I made some progress, I changed the default state for the unused pins to input-tristate and now I am getting the following error code:
Info (209060): Started Programmer operation at Tue Dec 14 00:43:55 2021
Info (209016): Configuring device index 2
Info (209017): Device 2 contains JTAG ID code 0x02D020DD
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209018): Device 2 silicon ID is 0x16
Error (209025): Can't recognize silicon ID for device 2. A device's silicon ID is different from its JTAG ID. Verify that all cables are securely connected, select a different device, or check the power on the target system. Make sure the device pins are connected and configured correctly.
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Tue Dec 14 00:43:59 2021Is this something that needs to be overwritten by hand or do I have some configuration files wrong?
Thank you!
Ernesto
