EFran7
7 years agoWrite Internal UFM Flas Memory of MAX10 Using Nios Command Shell
hi everyone,, I have to implement a way to write Flash data of a max 10 without opening Quartus. In particular I need to overwrite only the ufm part of the internal flash (UFM) of MAX10 through JTAG...
EFran7
7 years agothanks Cng,
but that was not what I meant.
However I have the answer, I hope it is useful to everyone.
To generate the pof file you need to use the command:
quartus_cpf -c file.cof
the cof file is an xml file that is generated by Quartus Programmer.
Report below the contents of the cof file:
<? xml version = "1.0" encoding = "US-ASCII" standalone = "yes"?>
<Cof>
<Output_filename> C: / ____ _________ filepath. Pof </ output_filename>
<N_pages> 1 </ n_pages>
<Width> 1 </ width>
<Mode> 14 </ mode>
<Sof_data>
<User_name> PAGE_0 </ user_name>
<Page_flags> 1 </ page_flags>
<Bit 0>
<Sof_filename> C: / ____ _________ filepath. Sof <compress_bitstream> 1 </ compress_bitstream> </ sof_filename>
</ Bit0>
</ Sof_data>
<Version> 10 </ version>
<Create_cvp_file> 0 </ create_cvp_file>
<Create_hps_iocsr> 0 </ create_hps_iocsr>
<Auto_create_rpd> 0 </ auto_create_rpd>
<Rpd_little_endian> 1 </ rpd_little_endian>
<Options>
<Map_file> 0 </ map_file>
</ Option>
<MAX10_device_options>
<Por> 0 </ por>
<Io_pullup> 1 </ io_pullup>
<Config_from_cfm0_only> 0 </ config_from_cfm0_only>
<Isp_source> 0 </ isp_source>
<Verify_protect> 0 </ verify_protect>
<Epof> 0 </ epof>
<Ufm_source> 2 </ ufm_source>
<Ufm_filepath> C: / ____ _________ filepath. HEX </ ufm_filepath>
</ MAX10_device_options>
<Advanced_options>
<Ignore_epcs_id_check> 2 </ ignore_epcs_id_check>
<Ignore_condone_check> 2 </ ignore_condone_check>
<Plc_adjustment> 0 </ plc_adjustment>
<Post_chain_bitstream_pad_bytes> -1 </ post_chain_bitstream_pad_bytes>
<Post_device_bitstream_pad_bytes> -1 </ post_device_bitstream_pad_bytes>
<Bitslice_pre_padding> 1 </ bitslice_pre_padding>
</ Advanced_options>
</ Cof>Once the pof file has been generated, it is possible to program the device with the command:
quartus_pgm -c
