15 years agowm8731 noise problem
Im trying to use the audio codec on the de2 board. I've written a verilog code to get the samples from the ADC and send it back to DAC. it's working well. I have designed a board which includes 4 aud...
15 years agoHi,
if the problem still exists, it would be interesting to know: Did you connect the I²C signals from FPGA to WM8731 correctly and what do you transmit over I²C to configure the WM8731. Or do you use it without configuring it (= default values)? Greetings
