BMart12
7 years agoWhat frame buffer address should I use for the vip framebuffer II parameter?
I instantiated the vip framebuffer II with the default address of 0x00000000. I am using the Tearsic DE10-Standard development board and Quartus 18.1 standard. I wrote a test program for Linux to e...
CheepinC_altera
7 years agoHi Ben,
Thanks for your update. Glad to hear that you have managed to get the FB II working by configuring the memory base address to a value other than 0x0.
Sorry if there is any confusion. Regarding your previous post, yes, I have receive the email. I understand that you have tested with TPG II -> CVO II. Thus, I am suggesting to test by adding FBII in between, ie TPG II -> FB II -> CVO II. Get the FB II up and running, then only remove the TPG II from the system. However, since you have managed to root cause the issue, it would be great for you to continue using your resolution to avoid gating your progress.
Chee Pin
