What frame buffer address should I use for the vip framebuffer II parameter?
Hi Ben,
Thanks for your update. As I understand it, when you use the example design from Terasic, there is no issue with the LCD display. Sorry as I am not really familiar with embedded area and also I am unable to comment on design implementation. However I will try my best to assist from the VIP perspective. Hope you could understand it.
Just would like to check with you on the following:
1. Just wonder if you if you have had a chance to try with a simple test design with Test Pattern Gen II -> Frame Buffer II -> CVO II -> LCD to see if there is any valid display on LCD? This would be helpful to ensure the FB II and CVO II IPs are working correctly prior to replacing the video source.
2. If #1 is working, you may start to replace the test pattern generator with your video source. This would help to narrow down the issue to video source if there is any issue observed.
3. You may also cross check your video data with the one from the Test Pattern Generator if #2 is not working. You may use signaltap to monitor the video data for cross checking.
Chee Pin
