cheye
6 years agoWhat does .pof file need to be converted to for MAX10 onchip CFM flash programming
Hi, While it is pretty clear that the UFM sections of the onchip Flash memory on MAX10 FPGAs are programmed with .hex files (and as the name suggests the.hex file is just a bunch of hex values), int...
KhaiChein_Y_Intel
6 years agoHi,
Which programmer are you using to program your Max 10? Is it the Quartus programmer or third party programmer. If you use the Quartus programmmer, you can directly program .sof or .pof into the Max 10. If you are using the third party programmer, you can use the .rpd file to program the Max 10 (This rpd can be generated when you convert .sof to .pof).
- KhaiChein_Y_Intel6 years ago
